Alternate Viewer
Manfred
Alternate Viewer
Post by Manfred »
Hello!
I configured MaxView as external viewer for *.JPG files and IrfanView as alternate viewer for *.JPG files. When I press F3 the image is correctly displayed by MaxView, but when I press ALT+F3 (or Files > Alternate View) the image is always displayed as hex view by the internal viewer.
I can't figure out what's wrong. What is my mistake?
Any hint is welcome!
Best regards
Manfred
Hi Manfred, Alternate Viewers are driven by Options > Configuration > Alternate Viewers.
The default alternate viewer is Internal Viewer. You can insert your own viewer there.
More information about viewers usage and configuration:
http://www.altap.cz/salam_en/help/salam ... k_view.htm
http://www.altap.cz/salam_en/help/salam ... _vwers.htm
Note: did you insert your viewer before "closing" Internal Viewer's *.*? Anything you append AFTER *.* will be ignored because file will be displayed by Internal Viewer (higher position in the list = higher priority).
Guest
Post by Guest »
Jan Rysavy wrote:Hi Manfred, Alternate Viewers are driven by Options > Configuration > Alternate Viewers.
More information about viewers configuration:
Hello Jan,
thank you for your quick reply. But that's exactly what I did (see attached image) - and it does not work, see my original post.
Regards, Manfred
Alternate Viewer.jpg (52.43 KiB) Viewed 10435 times
Yes, it is the problem. Please move your mask up, in front of *.*. Mask are executed top-down.
We should probably improve documentation and explain our term "priority list".
Guest
Post by Guest »
Jan Rysavy wrote:Yes, it is the problem. Please move your mask up, in front of *.*.
Got it!
My mistake - thanks very much!
Manfred
