Deleting empty undeleted files
mdruiter
After I undeleted an empty (0 bytes) file using the plugin, the resulting file cannot be deleted again. The message I get is:
Error Deleting File
Error: (32) The process cannot access the file because it is being used by another process.
It does not work until I close Salamander. Apparently the plugin keeps such a file open?
Error Deleting File
Reply?
The post was mine, but I did not log in until now. Please reply to this one instead!
cincura.net
cincura.net
Re: Deleting empty undeleted files
Process Explorer http://www.sysinternals.com/Utilities/P ... lorer.html can explain what program lock the file.
I prepare file with length 0 bytes. I delete it (without recycle bin). Then I restore it with undelete plugin to different partition and really, restored file was locked. But not with the plugin (I unload the plugin from the memory), but with SALAMAND.exe as an handle.
cincura.net
Yes, cause' the plugin is loaded by SS.jis wrote:But not with the plugin (I unload the plugin from the memory), but with SALAMAND.exe as an handle.
I think Altap should fix this.
Jiri {x2} Cincura
