Deleting empty undeleted files
mdruiter
Post by mdruiter »
After I undeleted an empty (0 bytes) file using the plugin, the resulting file cannot be deleted again. The message I get is:
Error Deleting File
Error: (32) The process cannot access the file because it is being used by another process.
It does not work until I close Salamander. Apparently the plugin keeps such a file open?
mdruiter
Reply?
Post by mdruiter »
The post was mine, but I did not log in until now. Please reply to this one instead!
cincura.net
Post by cincura.net »
Can you rename the folder where the file is?
Jiri {x2} Cincura
mdruiter
Post by mdruiter »
No, that gives me:
Error Renaming File
(5) Access is denied
cincura.net
mdruiter wrote:No, that gives me:
Error Renaming File
This seems, that the plugin has setted the working directory into the directory, so you're not able to delete files and/or folders.
Maybe the author of the plugin will say more.
Jiri {x2} Cincura
jis
Re: Deleting empty undeleted files
Post by jis »
Process Explorer http://www.sysinternals.com/Utilities/P ... lorer.html can explain what program lock the file.
I prepare file with length 0 bytes. I delete it (without recycle bin). Then I restore it with undelete plugin to different partition and really, restored file was locked. But not with the plugin (I unload the plugin from the memory), but with SALAMAND.exe as an handle.
cincura.net
jis wrote:But not with the plugin (I unload the plugin from the memory), but with SALAMAND.exe as an handle.
Yes, cause' the plugin is loaded by SS.
I think Altap should fix this. ;)
Jiri {x2} Cincura
I can reproduce this problem. Thank you for reporting it!
jis
Post by jis »
It was problem of plugin or Salamander itself?
jis wrote:It was problem of plugin or Salamander itself?
Don't know now, we will let you know...
Problem was fixed in SS 2.5 RC1. Could you please confirm it?
jis
Post by jis »
Jan Rysavy wrote:Problem was fixed in SS 2.5 RC1. Could you please confirm it?
Yes, I could. Thank you.
mdruiter
Post by mdruiter »
Confirmed, I guess this post can be flagged as fixed.
