Changing label on USB flash disk hangs up SS
- crystalidea
Simply try to change a removable drive (usb flash) label.
Re: Bug: Program Hangs!
When Servant Salamander hangs, start the second instace of SS, then from Help menu choose the Task List command. From the list select freezed instance and click the Break button.XPiS wrote:Simply try to change a removable drive (usb flash) label.
Bug Report should appear. Please email us this bug report (include the problem description). Thank you!
We met this problem before. Please let us know if you could reproduce any strange behaviour related to changing label of removable media.
To change drive label you can
1) use Drive Information window (Ctrl+F1)
2) from the Change Drive menu (Alt+F1/2) right click the drive item and from context menu choose the Properties command
It looks weird too. Could you then return to this disk? Please try to change label using Ctrl+F1 and let us know.Mem wrote:Done with no prob (USB stick, right-click on drive, properties, change label to something else) - the only thing SS does is changing drive in panels after I change the label (= can not find disk and changes to C: etc.)
Now I can reproduce the bug too - using Ctrl+F1 instead of Drive Properties causes hangup. I have sent bug report caused by the Break command to your e-mail.
To your other questions - Drive Properties works with no problem, SS just changes panel to my C: but I can then switch back to flash drive and everything is working
