The thumbnails of JPGs exported from Adobe Lightroom 5.6 are not displayed by Altap Salamander. Please add support for the changes made by Adobe. All other programs i use show the thumbnails correctly. Attached you find a file to test it yourself.
Thanks
Stephan
Thumbnails of JPGs exported from LR 5.6 not recognized
- B20140630_112910_IMG_1228.jpg (138.62 KiB) Viewed 13561 times
Re: Thumbnails of JPGs exported from LR 5.6 not recognized
Related thread in Czech: Zobrazování miniatur
Note that if you check "Ignore original thumbnails stored in image files (slower)" in PictView settings, thumbnails start to appear.
Přikládám ukázkový soubor. Ano, ta volba pomohla. Ale je to zajímavé, nenapadlo mě, že Pictview ovlivňuje i miniatury, navíc když v prohlížení na F3 ho zobrazuje správně. Ale každopádně díky za radu.
Thanks for this advice. I will use this setting as a workaround until the embedded thumbnails of the new JPGs are recognized.Ether wrote:Note that if you check "Ignore original thumbnails stored in image files (slower)" in PictView settings, thumbnails start to appear.
Stephan
I hoped the new version 3.03 addressed this problem, but disappointingly it doesn't. The workaround "Ignore original thumbnails stored in image files (slower)" is so painfully slow! I really hope that this problem will be addressed with the upcoming version.
Stephan
Stephan
