Thumbnails of JPGs exported from LR 5.6 not recognized
StephanP
Post by StephanP »
The thumbnails of JPGs exported from Adobe Lightroom 5.6 are not displayed by Altap Salamander. Please add support for the changes made by Adobe. All other programs i use show the thumbnails correctly. Attached you find a file to test it yourself.
Thanks
Stephan
Re: Thumbnails of JPGs exported from LR 5.6 not recognized
Related thread in Czech: Zobrazování miniatur
Note that if you check "Ignore original thumbnails stored in image files (slower)" in PictView settings, thumbnails start to appear.
MilosFMT
Post by MilosFMT »
Přikládám ukázkový soubor. Ano, ta volba pomohla. Ale je to zajímavé, nenapadlo mě, že Pictview ovlivňuje i miniatury, navíc když v prohlížení na F3 ho zobrazuje správně. Ale každopádně díky za radu.
StephanP
Post by StephanP »
Ether wrote:Note that if you check "Ignore original thumbnails stored in image files (slower)" in PictView settings, thumbnails start to appear.
Thanks for this advice. I will use this setting as a workaround until the embedded thumbnails of the new JPGs are recognized.
Stephan
StephanP
Post by StephanP »
I hoped the new version 3.03 addressed this problem, but disappointingly it doesn't. The workaround "Ignore original thumbnails stored in image files (slower)" is so painfully slow! I really hope that this problem will be addressed with the upcoming version.
Stephan
