beta 3: has WinSCP plugin been changed (problem)?
crystalidea
Post by crystalidea »
The problem I'm facing during browsing SFTP directories is that an error message pops out saying that packet is corrupted, and the connection is automatically closed (with optional ability to re-connect). Never faced the issue using the previous EAP. Please help! It happens not really often but very annoying
Re: beta 3: has WinSCP plugin been changed (problem)?
Could you please post screenshot with the error message?
crystalidea
Yes, sure, next time I see it
crystalidea
The problem doesn't happen if previous EAP! The current version of WinSCP is buggy, it happens all the time now
There're 2 variants of error message, one with auto-reconnect timer button (didn't manage to catch it)
The second is this (the connection to server was immediately closed)
Martin Prikryl
Post by Martin Prikryl »
I do not think there was any change in Beta 3 that may cause this.
Anyway, can you please attach a complete session log file showing the problem?
Martin Prikryl
https://winscp.net/
crystalidea
Where can I get it?
PS. Some info:
Here it is:
