beta 3: has WinSCP plugin been changed (problem)?
- crystalidea
The problem I'm facing during browsing SFTP directories is that an error message pops out saying that packet is corrupted, and the connection is automatically closed (with optional ability to re-connect). Never faced the issue using the previous EAP. Please help! It happens not really often but very annoying
Re: beta 3: has WinSCP plugin been changed (problem)?
Could you please post screenshot with the error message?
- crystalidea
Yes, sure, next time I see it
- crystalidea
The problem doesn't happen if previous EAP! The current version of WinSCP is buggy, it happens all the time now
There're 2 variants of error message, one with auto-reconnect timer button (didn't manage to catch it)
The second is this (the connection to server was immediately closed)
- sshot-7.png (42.23 KiB) Viewed 18657 times
Martin Prikryl
I do not think there was any change in Beta 3 that may cause this.
Anyway, can you please attach a complete session log file showing the problem?
Martin Prikryl
https://winscp.net/
https://winscp.net/
- crystalidea
Where can I get it?
PS. Some info:
PS. Some info:
- sshot-1.png (3.69 KiB) Viewed 18604 times
Here it is:
- log.png (30.26 KiB) Viewed 18554 times
