I usually keep Salamander running so I have easy access to it. The Beta keeps crashing while not doing anything at all. I have sent the error reports to Altap when it crashes.
George
Salamander 3.0 Beta 1 (x64) crashes while idle
Forum rules
Re: Salamander 3.0 Beta 1 (x64) crashes while idle
Thank you for your bug reports. The problem is in Google Drive shell extension, we will try to patch next build of Salamander to fix it.
- googledrive.png (22.66 KiB) Viewed 81078 times
Andre.Ziegler
disable sync icons in google drive options. This bug also causes Explorer crashes.
