Salamander 3.0 Beta 1 (x64) crashes while idle
Forum rules
gworley
Post by gworley »
I usually keep Salamander running so I have easy access to it. The Beta keeps crashing while not doing anything at all. I have sent the error reports to Altap when it crashes.
George
Re: Salamander 3.0 Beta 1 (x64) crashes while idle
Thank you for your bug reports. The problem is in Google Drive shell extension, we will try to patch next build of Salamander to fix it.
Andre.Ziegler
Post by Andre.Ziegler »
disable sync icons in google drive options. This bug also causes Explorer crashes.
