i accidently moved SS to my second Monitor (ATI-Dual Pane).
After switching back to my normal primary Monitor (i use the second Monitor only sometimes, so it's powered off the most time)
SS opens every Window (Viewer) in the second Monitor.
Even if i make a restart of SS it opens on the second monitor.
How can i force SS to start and use only my primary Monitor ?
Thanks in Advance.
Dual Monitor Problem
Mike
Thanks Jan for your fast answer.
But i have already installed Servant Salamander 2.5 beta 11.
The problem occurs with this version.
Should i uninstall and reinstall it or is there a newer Version
available ?
Meanwhile i've looked in the Configuration Reg-File
but was unable to find a corresponding entry.
Is there anything i can do ?
Thanks for your help.
available ?
Re: Dual Monitor Problem
If you have problem with Internal viewer, look atMike wrote:SS opens every Window (Viewer) in the second Monitor.
Servant Salamander > Options > Internal Viewer > Window position.
Please let me know.
