Dual Monitor Problem
Mike
Post by Mike »
i accidently moved SS to my second Monitor (ATI-Dual Pane).
After switching back to my normal primary Monitor (i use the second Monitor only sometimes, so it's powered off the most time)
SS opens every Window (Viewer) in the second Monitor.
Even if i make a restart of SS it opens on the second monitor.
How can i force SS to start and use only my primary Monitor ?
Thanks in Advance.
Mike, please try to install Servant Salamander 2.5 beta 11. This problem was already fixed.
Mike
Post by Mike »
Thanks Jan for your fast answer.
But i have already installed Servant Salamander 2.5 beta 11.
The problem occurs with this version. :shock:
Should i uninstall and reinstall it or is there a newer Version
available ?
Meanwhile i've looked in the Configuration Reg-File
but was unable to find a corresponding entry.
Is there anything i can do ?
Thanks for your help.
Re: Dual Monitor Problem
Mike wrote:SS opens every Window (Viewer) in the second Monitor.
If you have problem with Internal viewer, look at
Servant Salamander > Options > Internal Viewer > Window position.
Please let me know.
Mike
Post by Mike »
Thanks Jan.
I do not know how, but the Problem is solved.
