Shift+Enter -> Open Name in Other Panel
randich
Post by randich »
...and Alt+Shift+Enter -> Focus Name in Other Panel
Curiously, theese commands are not available in the menus; I found them in Options / Customize / Top Toolbar...
:cry: It's a pity not to have shortcut keys for theese commands, because for me they are at the root of two-panel directory navigation.
A more advanced feature should be automatic directory change in the other panel. I focus one folder in a panel and the other shows me its contents automatically (or file content).
All Servant Salamander keyboard shortucts are listed at
http://www.altap.cz/salam_en/features/keyboard.html
KNUT
Post by KNUT »
Jan Rysavy wrote:All Servant Salamander keyboard shortucts are listed at http://www.altap.cz/salam_en/features/keyboard.html
...but there I do not find the above mentioned commands - am I blind 8) :?:
Kind regards, KNUT
jis
Post by jis »
It is here - Open the focused directory or archive in the passive panel:
Ctrl+Shift+Left
Ctrl+Shift+Right
* You can choose if the passive panel will be activated using Left/Right key
Original post is misleading...
KNUT
Post by KNUT »
jis wrote:It is here
.. I _am_ blind 8)
jis, thanks! :P
Kind regards, KNUT
