Changing Hard Coded Link "Documents"
vld
Post by vld »
Is there a way to change where the link Documents points to? My Documents reside on drive D vs C and would like to open that specific folder.
Re: Changing Hard Coded Link "Documents"
On which operating system? AFAIK Salamander takes this location from registry. Its not hardcoded.
Verify that this registry key points to your location:
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Shell Folders
 Value Name: Personal
 Value Type: REG_SZ
 Value Data: path
SelfMan wrote:Verify that this registry key points to your location:
You should not modify the registry key directly, though. Rather use the Path tab on the documents folder's property dialog.
Appears you must do that from within Windows Explorer (as "the magic path" <Target> does not display when the folder Properties is opened from within Salamander).
Related: Nirsoft SpecialFoldersView - Easily jump to special folders in Windows
