file viewer for msg extension
jpermana
Post by jpermana »
Hi
I am trying to use plugin file viewer for msg extension (outlook format), but never work.
Can someone help me, please.
Thanks
Re: file viewer for msg extension
There is no dedicated viewer for Outlook format in Altap Salamander.
What plugin do you mean?
jpermana
Post by jpermana »
Hi Jan,
I usually use F3 to run quick read on the file, but it won't work for file with extension msg. The plugin I am talking about is Eroiica Viewer.
Thx
jpermana wrote:I usually use F3 to run quick read on the file, but it won't work for file with extension msg. The plugin I am talking about is Eroiica Viewer.
Why do you think the Outlook Message Format is supported by Eroiica Viewer? It actually is not supported and never was...
jpermana
Post by jpermana »
Well, if never supported before, maybe this is for feature request.... :lol:
Could you specify what are those msg files in more detail, then? I know it can probably found somewhere on the Internet, but I'd like to hear it from you, too - to prevent confusion.
jpermana
Post by jpermana »
msg files is for outlook messages. I can open it with outlook after I save the file. I am just wondering if I can open it using viewer feature from salamander.... :D
Brett
Post by Brett »
The msg file saved from Outlook (2010 in my case) is a compound document with many streams so a viewer for this would, to my mind, be quite difficult to implement.
Cheers,
Brett
jpermana wrote:I am just wondering if I can open it using viewer feature from salamander.... :D
So I guess the answer is no. You can make a Feature Request for this. Or you could try saving your emails using the EML format which Salamander supports.
HINT: MSG2EML Converter Freeware, Requires.NET Framework 4
jpermana
Post by jpermana »
thx selfman
