file viewer for msg extension
Hi
I am trying to use plugin file viewer for msg extension (outlook format), but never work.
Can someone help me, please.
Thanks
Thanks
Re: file viewer for msg extension
There is no dedicated viewer for Outlook format in Altap Salamander.
What plugin do you mean?
Hi Jan,
I usually use F3 to run quick read on the file, but it won't work for file with extension msg. The plugin I am talking about is Eroiica Viewer.
Thx
Thx
Why do you think the Outlook Message Format is supported by Eroiica Viewer? It actually is not supported and never was...jpermana wrote:I usually use F3 to run quick read on the file, but it won't work for file with extension msg. The plugin I am talking about is Eroiica Viewer.
Well, if never supported before, maybe this is for feature request....
Could you specify what are those msg files in more detail, then? I know it can probably found somewhere on the Internet, but I'd like to hear it from you, too - to prevent confusion.
msg files is for outlook messages. I can open it with outlook after I save the file. I am just wondering if I can open it using viewer feature from salamander....
The msg file saved from Outlook (2010 in my case) is a compound document with many streams so a viewer for this would, to my mind, be quite difficult to implement.
Cheers,
Brett
Cheers,
Brett
So I guess the answer is no. You can make a Feature Request for this. Or you could try saving your emails using the EML format which Salamander supports.jpermana wrote:I am just wondering if I can open it using viewer feature from salamander....
HINT: MSG2EML Converter Freeware, Requires.NET Framework 4
