Broken images in Markdown viewer
zorglups
Post by zorglups »
Hello,
Happy to see support for Markdown in Altap Salamander.
The viewer shows broken images.
If I right click and select "View Source", notepad opens and I see that the image HTML code is this:
<img src=".%5CzZ_assets%5CAnki.assets%5C1546471044201.png" alt="1546471044201" />
If I save the "viewed source" into an html file and view that html file with the Altap Salamander viewer, the image displays fine.
Is that a known problem ?
Thanks,
Pierre
Re: Broken images in Markdown viewer
The viewer uses the about: scheme. Since your url did not use it's own scheme, the viewer could not locate the resource.
It's probably the same reason pressing F5 leaves you with an empty screen.
@Altap: maybe add a <base>-tag pointing to the .md's folder in order to fix @zorglups' problem?
I now tried to add an image myself. Knowing that a relative path does not work I tried an absolute path, including file: scheme. This cause the resulting src property to be the empty string:
![Skizze](file://HOST/SHARE/Path/image.jpg)
results in
<img src="" alt="Skizze" />
Is this a bug or a security feature? Do I need to set up a web server in order to be able to embed pictures?
powerlicht
Post by powerlicht »
I couldn't get the relative path to work either. I've created something that allows me to repair the local image links again and again. They have to be present in the MarkDown files as an absolute local path.
It took a moment for me to get the regex for search and replace to work, but it works great: Demo > regexstorm.net
The local image path must not contain any spaces!
I created a test folder on drive Y using:
I also added my batch file to the structure, in the same location as the MarkDown files
Drag and drop one or more directories onto the batch file. A menu appears, which then allows you to use the new image directory for the image link. A directory called 'fixed' is automatically created and, if it already exists, generated with a consecutive number. The new Markdown files are stored there.
MD-Helper_fix-ImagePath___DragDrop-ImagePath.cmd
  @echo off
  :: Path-List transfer to powershell as UniCode!!!
	:: ECHO ---------------------------------------------------------
	:: ECHO.ECHO %%*:
	:: ECHO %*
	ECHO %* | clip
	:: ECHO.Powershell:
    powershell /nologo /noprofile /ExecutionPolicy bypass /command ^
         "&{[ScriptBlock]::Create((cat """%~f0""") -join [Char[]]10).Invoke(($args = '%*'))}"
    ECHO.
  pause
  pause
  pause
  pause
  pause
  pause
  pause
  pause
  REM exit /b
$text = @{
    WindowTitleStarttitle  = "Fix absolute local image paths in MD-Files"
    WindowTitleMenuIMGpath = "select Image-Folder"
    #write-host messages:
    wh__NotPathFound  = "no Path(s) found ... Drop a path 'A:\' or 'Z:\abc\md-images'...`nPath with SPACES is forbidden. Spaces in Path is Problem for local-path"
    #write-verbose messages
    wv__MDfileOK      = "MD-FilePath is ok!"
    wv__ParsePath     = "Parse Path-Info from Drop-List"
    wv__SelectedIMGpath_0 = "selected MD-Image-Path"
    #write-warning messages
    ww__MDfileFail    = "MD-FilePath is not working!"
#region definition HOST / ISE
    if ($host.name -eq 'ConsoleHost'){
        $host.UI.RawUI.WindowTitle = $text.WindowTitleStarttitle
        $host.PrivateData.WarningBackgroundColor = "black"
        $host.PrivateData.WarningForegroundColor = "red"
        $host.PrivateData.VerboseBackgroundColor = "black"
        $host.PrivateData.VerboseForegroundColor = "darkcyan"
        $location = @{ hier = (get-item '.')}
    }else{
        # ISE...
#endregion
#region functions
    function Main {
        [cmdletbinding()]param()
        # return from ClipBoard only DirectoryPaths
        $pfade = get-Paths-from-clipbaord
        Write-Verbose $text.wv__ParsePath
        if ($pfade.count -gt 0){
            # return only exactly MD-DirectoryPaths
            $mdPfade = getPathForMDLinks -pathListe $pfade -Verbose
        }else{
            Write-host -b DarkRed -f White $text.wh__NotPathFound
        if($mdPfade.count -ge 1) {
            # MD-Files
            $md_files = Get-ChildItem $location.hier -file | ? {$_.Extension -eq '.md' }
            # Menu
            write-host -b DarkCyan -f black ("`nMenu-Auswahl f$([char]252)r IMG-Pfad ... {0} MD-Files gefunden" -f $md_files.count)
            $host.UI.RawUI.WindowTitle = $text.WindowTitleMenuIMGpath + " f$([char]252)r MD-Files: [" + $location.hier + ']'
            do {
                menu-aus-parameterListe-erstellen -Text_fuer_Menuzeilen $mdPfade.fullname
                $menu_auswahl = read-host -Prompt "`n"
            }while(1..$mdPfade.count -notcontains $menu_auswahl)
            Write-Verbose ("$($text.wv__SelectedIMGpath_0) [$($mdPfade[$menu_auswahl-1])]"  )
            # IMG-Path
            $imagePath = get-item $mdPfade[$menu_auswahl-1].fullname
            # 1 / 5 - create new MD-File-Folder 'fixed[1-9]+'
            $fixed_path = create-folder-mit-fortlaufender-Nummer -savePath (Join-Path -Path $location.hier -ChildPath "fixed" )
            # 2 / 5 - Foldername for 'fixed[1-9]+'
            # file system refresh to slow? if now created a folder 'fixed3' and this function found old 'fixed2'
            # fixed_path = get-folder-mit-fortlaufender-Nummer -Path (Join-Path -Path $location.hier -ChildPath "fixed" )
            Write-Verbose "fixed_path [$($fixed_path)]" # ;  Write-Verbose "locat_hier [$($location.hier)]"
            # 3 / 5 - read original-md-file > replace img-path > write new-md-file into new 'fixed'-Folder
            $imagePath = (Join-Path -Path $imagePath -ChildPath "") -replace '\\','//'
            foreach ($mdf in $md_files)
                #[System.IO.File]::ReadLines($mdf)
                #$reader = New-Object System.IO.StreamReader($mdf.FullName  , [System.Text.Encoding]::Unicode)
                $reader = New-Object System.IO.StreamReader($mdf.FullName  )
                #$writer = New-Object System.IO.StreamWriter("$( Join-Path -Path $fixed_path -ChildPath $mdf.name )", $true, [System.Text.Encoding]::Unicode) # the true means to "append"
                $writer = New-Object System.IO.StreamWriter("$( Join-Path -Path $fixed_path -ChildPath $mdf.name )", $true) # the true means to "append"
                while ($reader.Peek() -ge 0) {
                    $tmp = $reader.ReadLine()
                    # ---- $tmp = $tmp -replace '(?<=!\[.*?\]\()(?<Path>.*?)(?=[^\/\\]*?\))', $imagePath
                    $patt = '(?<=!?\[.*?\]\()(?<Path>[a-z]:.*?)(?=[^\/\\]*?\))'
                    $tmp = $tmp -replace $patt , $imagePath
                    <# replace :
                            sample-1: ![system.io.directory_getFreeDriveLetter.png](C:\Helfer-Powershell\Hilfe\images\system.io.directory_getFreeDriveLetter.png)
                            sample-2: ![system.io.directory_getFreeDriveLetter.png](C:/Helfer-Powershell/Hilfe/images/system.io.directory_getFreeDriveLetter.png)
                            sample-3: ![system.io.directory_getFreeDriveLetter.png](C:\\Helfer-Powershell\\Hilfe\\images\\system.io.directory_getFreeDriveLetter.png)
                            sample-4: ![system.io.directory_getFreeDriveLetter.png](C://Helfer-Powershell//Hilfe//images//system.io.directory_getFreeDriveLetter.png)
                        to:
                      sample-1+2+3+4: ![system.io.directory_getFreeDriveLetter.png](Y://images/system.io.directory_getFreeDriveLetter.png)
                    $writer.writeline($tmp )
                $reader.Close()
                $writer.Close()
            } # END - foreach write new md-files
        } # END - if $mdpfade.count
    } # END - function Main
    function get-Paths-from-clipbaord {
        # FilePaths from Drag'nDrop over Batch-File
        $paths = [System.Windows.Forms.Clipboard]::GetText() -replace '"' |
            Where-Object   { $_ -match '[a-z]:' } |
            ForEach-Object { ($_ -split $Matches[0] ).trim() -join "`n$($Matches[0])" -split '\n' } |
            Where-Object   { $_ -ne "" } |
            Where-Object   { [System.IO.Directory]::Exists($_) } |
            ForEach-Object { Get-Item $_ }
        return $paths
    function getPathForMDLinks {
        [CMDletbinding()]
        param ($pathListe)
        # $ret = $pathListe | ? { $_ -notmatch '[ ]' }
        $ret = $pathListe | <# ? { [System.IO.Directory]::Exists($_)} | #>
            if ( $_ -notmatch '[ ]' ){
                Write-Verbose "$($text.wv__MDfileOK) [$($_.fullname)]"
                $_
            }else{
                Write-Warning "$($text.ww__MDfileFail) [$($_.fullname)]"
        return $ret
    function menu-aus-parameterListe-erstellen {
        param($Text_fuer_Menuzeilen, $Text_fuer_Exit_Menuzeile)
    #    write-host -b darkblue -f white ("`nW$([char]228)hle eine Ziffer aus ("   ) -non
    #    write-host -b Black    -f Green ("0"   ) -non
    #    write-host -b darkblue -f white (" = Exit):"   )
        $i = 0;
        $leer    = " "
        $Text_fuer_Menuzeilen_intern = @("")
        $Text_fuer_Menuzeilen_intern += $Text_fuer_Menuzeilen
        # write-host -b DarkGreen (($Text_fuer_Menuzeilen_intern | sort {$_.length})[-1].length)
        $max_spc = (($Text_fuer_Menuzeilen_intern, $Text_fuer_Exit_Menuzeile | sort {$_.length})[-1].length) +1
        # if ($max_spc -lt 30) {$max_spc = 30}
        $spaces  = (" "*$max_spc)
        $exit    =  $Text_fuer_Exit_Menuzeile
                         # -1 > 1 Space ganz vorne
                         # -1 > 1 Space ganz hinten
                         # -$leer.length  > Abstand vor+hinter dem Wort, welches mittig sein soll
                         # -Wortlaenge >
                         # exit_weite > welche dann als Leerraumfueller vorher und Nachher zerteilt wird
        $exit_weite = ($max_spc -1  -$leer.Length -$leer.Length -$exit.Length )
        $exit_fuer_menu =   "{0}{2}{3}{2}{1}" -f
            ("-" *([math]::Truncate($exit_weite/2)  + ($exit_weite % 2))) ,
            ("-" *([math]::Truncate($exit_weite/2) )) ,
            $leer ,
            $exit
        function ZeilenMenuAufbauen {
            param ($zeile, $zeilenNummer)
            # $max_spc = 45
    #write-host -b darkyellow -f white ("[$zeile] --- [$($zeile.length)]" )
            # $item += (" "*$max_spc)
            # $endspc = (($params | sort {$_.length} | % {$_.length})[-1]) +1 - ($item.length)
            write-host -non -f Green ("`n {0,3} " -f $zeilenNummer ) # ++$i)
            write-host -non -f darkGray ("[" )
            write-host -non -b Cyan -f Black (" {0}" -f "$($zeile)$($spaces)".Substring(0,$max_spc) )
            #write-host -non -b Cyan -f Black (" {0}" -f $zeile.Substring(0,$max_spc) )
            Write-Host -f DarkGray ("]")
            if($exit.length -gt 0){ ZeilenMenuAufbauen -zeile $exit_fuer_menu -zeilenNummer $i $max_spc}
        foreach ($item in $Text_fuer_Menuzeilen)
            ++$i
            ZeilenMenuAufbauen -zeile "$item" -zeilenNummer $i
    # Fortlaufende Nummerierung  fuer den Save-Ordner generieren
    function create-folder-mit-fortlaufender-Nummer {
        param(
            [string]$savePath
            if (Test-Path "$($savepath)*")
                $tmpg =  Get-ChildItem  "$($savepath)*"   `
                         | ? { $_.BaseName -match "([0-9]+)$"} `
                         | % {[int]$Matches[1]} | sort | select -Last 1
                $savepath +=  if ($tmpg.count -eq 0) {1}else{ $tmpg  +1}
            new-item -Path $savepath -ItemType Directory -ErrorAction SilentlyContinue -Verbose | Out-Null
            return $savePath
        # Testausgabe:
        #    $savepath
    function get-folder-mit-fortlaufender-Nummer {
        param( [string]$Path )
        if (Test-Path "$($Path)*")
            $Path =  Get-ChildItem  "$($Path)*"   `
                        | Where-Object { $_.BaseName -match "([0-9]+)$"} `
                        | sort {[int]$Matches[1]} `
                        | select -Last 1
            return $Path
#endregion
# START:
Main  -Verbose
Edit, 22.Januar.2025
i have the batch-file modified, old:
new:
powerlicht wrote: 20 Jan 2025, 18:27 I couldn't get the relative path to work either.
I see you use a AS v5.0.
Where it is from? Some news inside, against v4.0?
Thanks.
pjj
Post by pjj »
AD7 wrote: 02 Feb 2025, 00:24 I see you use a AS v5.0.
Link was posted just yesterday. I wish it was more prominent, too.
I don't know what exactly has been added, but WebP preview works fantastic!
pjj wrote: 02 Feb 2025, 08:18
Thanks, I thought there was another one somewhere. :D
Quick compare of Plugins folder AS 4 vs AS 5:
powerlicht
Thanks.
i have download OpenSalamander v5.0 from a fork (Dec 30, 2024):
https://github.com/OFreddy/salamander
