WinSCP: tranfer file between remote server
Hi
Can we add feature for transfer file between 2 remote server ??
Thanks
Thanks
- error1.JPG (104.41 KiB) Viewed 27523 times
Reason: Updated subject
Re: tranfer file between remote server
This request is already here multiple times. i.e. here
Search for FXP.
Search for FXP.
Wow...thx...but this request started about 4 years ago and no update ??????
The old request is about FTP plugin. You are talking about WinSCP. Totally different code paths.
Re: WinSCP: tranfer file between remote server
I see...so is there a feature for transfer file when using winscp ?
Thx
Thx
Yes, your request
I think that WinSCP 1.6.3 in Salamander 2.53 beta 1 can copy/move in scope of one server (I think it's your case), just try F5/F6 and Enter, it should work.
(Just to point out ... note the Error message in the screenshot above. Scroll down to see.)
Thanks, I have overlooked that. It seems that it's not working with 2.53 beta 1 (at least if the messagebox is reaction to Copy/Move command). BUT: I have tested it with 2.53 beta 1 and with two paths with "scp://" prefix (SCP connections) Copy/Move works well. With "sftp://" prefix (SFTP connections) it works too. I have connected to Linux server, so maybe that is the difference. I'll ask Martin Prikryl to clarify this.therube wrote:(Just to point out ... note the Error message in the screenshot above. Scroll down to see.)
Martin Prikryl
It works for me too. What did you exactly do to get the error message?
Martin Prikryl
https://winscp.net/
https://winscp.net/
Hi Martin,
I am using F5 for copy, and yes it works if working within one server. I am connecting Server A on left, and Server B on right, I want to transfer file either copy or move from Server A to Server B. The error message when copy file from server A to server B.
Thx
Thx
Hi Martin,
Do you have any updates ? I am really in need this feature for my work....
Thx
Thx
Hello Altap,
When are you going to implement this feature ??
Transfer file between 2 different remote server not working, remote edit not available, tab browsing not available.
I tried Speed commander and all feature above available with less price.... come on.??!!??
JP
JP
Unfortunately there is missing infrastructure on Salamander side and these features cannot be implemented in WinSCP plugin now. We have it on our to-do list.
Btw, the current price of Salamander with WinSCP and PictView plugin is $47.85. Price of SC is $56.
I paid this amount.
- altap.jpg (11.98 KiB) Viewed 27096 times
