WinSCP: tranfer file between remote server
jpermana
Post by jpermana »
Hi
Can we add feature for transfer file between 2 remote server ??
Thanks
Reason: Updated subject
Re: tranfer file between remote server
This request is already here multiple times. i.e. here
Search for FXP.
jpermana
Post by jpermana »
Wow...thx...but this request started about 4 years ago and no update ?????? :roll:
The old request is about FTP plugin. You are talking about WinSCP. Totally different code paths.
jpermana
Re: WinSCP: tranfer file between remote server
Post by jpermana »
I see...so is there a feature for transfer file when using winscp ?
Thx
Yes, your request :)
I think that WinSCP 1.6.3 in Salamander 2.53 beta 1 can copy/move in scope of one server (I think it's your case), just try F5/F6 and Enter, it should work.
(Just to point out ... note the Error message in the screenshot above. Scroll down to see.)
therube wrote:(Just to point out ... note the Error message in the screenshot above. Scroll down to see.)
Thanks, I have overlooked that. It seems that it's not working with 2.53 beta 1 (at least if the messagebox is reaction to Copy/Move command). BUT: I have tested it with 2.53 beta 1 and with two paths with "scp://" prefix (SCP connections) Copy/Move works well. With "sftp://" prefix (SFTP connections) it works too. I have connected to Linux server, so maybe that is the difference. I'll ask Martin Prikryl to clarify this.
Martin Prikryl
Post by Martin Prikryl »
It works for me too. What did you exactly do to get the error message?
Martin Prikryl
https://winscp.net/
jpermana
Post by jpermana »
Hi Martin,
I am using F5 for copy, and yes it works if working within one server. I am connecting Server A on left, and Server B on right, I want to transfer file either copy or move from Server A to Server B. The error message when copy file from server A to server B.
Thx
jpermana
Post by jpermana »
Hi Martin,
Do you have any updates ? I am really in need this feature for my work.... :mrgreen:
Thx
jpermana
Post by jpermana »
Hello Altap,
When are you going to implement this feature ??
Transfer file between 2 different remote server not working, remote edit not available, tab browsing not available.
I tried Speed commander and all feature above available with less price.... come on.??!!?? :oops:
JP
Unfortunately there is missing infrastructure on Salamander side and these features cannot be implemented in WinSCP plugin now. We have it on our to-do list.
Btw, the current price of Salamander with WinSCP and PictView plugin is $47.85. Price of SC is $56.
jpermana
Post by jpermana »
I paid this amount.
