error sftp on altap 2.52 - connection refused
I tried SFTP with altap salamander 2.52 and got error, while working fine with Altap salamander 2.51.
Any idea why ?? and how to resolve it ??
- error message
- error_winscp.jpg (164.83 KiB) Viewed 24882 times
Re: error sftp on altap 2.52
Are you using any firewall on your computer? It looks like Salamander is blocked. Could you connect using FTP plugin to our (ALTAP) bookmark?
What about Plugins > Check Version > Check for new versions, does it work?
Hi Jan,
The firewall is Off. Also I was able to FTP to Altap bookmark (both 2.51 and 2.52)
The winscp plugin version is 1.62 for Altap 2.52 and version 1.51 for Altap 2.51.
Martin Prikryl
Following link describes common causes of this error for WinSCP application. They mostly apply to WinSCP plugin for Altap Salamander, with the only difference being that the plugin does not support FTP protocol.
http://winscp.net/eng/docs/message_connection_refused
Martin Prikryl
https://winscp.net/
https://winscp.net/
Martin Prikryl
Also, if the link does not help, please post a log files both from 2.52 and 2.51. See logging pane on WinSCP login dialog.
Martin Prikryl
https://winscp.net/
https://winscp.net/
Hi Martin,
Attached comparison Altap 2.52 and Altap 2.51. On Altap 2.51, I tried SFTP, SFTP (allow SCP fallback) and SCP, all works, mean I can connect. On Altap 2.52, none of these configuration work, all with the same result "network error : Connection refused"
How do I get the log file ?
Thanks
Thanks
- error_winscp1.jpg (486.46 KiB) Viewed 24825 times
Please setup both WinSCP to create log files:
Thanks Jan,
Attached log collected from altap 2.51 and altap 2.52.
- log.zip
- (3.49 KiB) Downloaded 903 times
Hi Jan, Martin,
I found the problem.
Thanks
Thanks
What was the problem?
can not use localhost, i have to put 127.0.0.1
I just looking at the log, then there's the problem.
I encountered the same problem in another program (on W7x64) just yesterday. The lookup for localhost returns an IPv6 address and an invalid/unusable IPv4 address. In my case, the IPv4 address was 0.0.0.0.
Re: error sftp on altap 2.52 - connection refused
Yes, reopening this problem. I can confirm there is problem with WinSCP on x64 Windows 7. localhost is resolved as "::1" instead of "127.0.0.1". It does work in FTP client so it looks to be WinSCP related.
Hi Jan,
So is this fix on altap 2.52 ?
Martin Prikryl, author of WinSCP plugin, is still working on it.
