Hi
I would like to remove arbitrary caracters, that is all charatcers after the first "_", see example:
to =>
How is this done?
Thanks.. André
Renamer - Remove arbitrary caracters
Re: Renamer - Remove arbitrary caracters
Search for "_.*". Select: Regular expression + Exclude extension.
- Clipbrd1.png (39.71 KiB) Viewed 11134 times
Thanks, You saved a lot of time..
