I get many files from suppliers in China, and they always use chinese names in files. But this gives a real problem. I only get ???? as file name letters, this maybe the choice of font I am unsure.
Windows explorer has no problems with the file names.
Chinese characters
Re: Chinese characters
Hi Mike, it's "Unicode" problem (try to search this forum). Unfortunately Unicode is not supported in Altap Salamander.
http://www.cedes.com.cn/web/pdf/106172e ... GRS_12.pdf
causes an error message with chinese letters, saved by the Internet Explorer as
无法找到网页.mht
(with "Subject: =?gb2312?B?zt63qNXStb3N+NKz?=" inside), but shown in Altap Salamander 2.52 as
??????.mht
F2, F3, Alt-F3 and F4 works anyway, F5 and F6 cause Error 123 (wrong syntax), but only if the filename is not changed by F2 before.
无法找到网页.mht
??????.mht
It's missing Unicode support, please see http://www.altap.cz/salam_en/help/salam ... upport.htm
