Chinese characters
mikeybabes
Chinese characters
Post by mikeybabes »
I get many files from suppliers in China, and they always use chinese names in files. But this gives a real problem. I only get ???? as file name letters, this maybe the choice of font I am unsure.
Windows explorer has no problems with the file names.
Re: Chinese characters
Hi Mike, it's "Unicode" problem (try to search this forum). Unfortunately Unicode is not supported in Altap Salamander.
TÜV
Post by TÜV »
http://www.cedes.com.cn/web/pdf/106172e ... GRS_12.pdf
causes an error message with chinese letters, saved by the Internet Explorer as
无法找到网页.mht
(with "Subject: =?gb2312?B?zt63qNXStb3N+NKz?=" inside), but shown in Altap Salamander 2.52 as
??????.mht
F2, F3, Alt-F3 and F4 works anyway, F5 and F6 cause Error 123 (wrong syntax), but only if the filename is not changed by F2 before.
It's missing Unicode support, please see http://www.altap.cz/salam_en/help/salam ... upport.htm
