Ctrl+Alt+F11 in Find
Could Ctrl+Alt+F11 (FullScreen) perhaps also be made to work in Find?
							Groente, Michel.
						Re: Ctrl+Alt+F11 in Find
Strange, unlike in Explorer (Vista), in my AS it is Ctrl+Shift+F11
EDIT: But in Internal Viewer it is only F11, which is windows standard (works in Explorer too)
In Find it is unfortunately missing...I think F11 should be added
Maybe both Ctrl-Shift+F11 *and* F11!
I did not realize until now, that I typed Ctrl+Alt+F11 where I meant Ctrl+Shift+F11.MartinS wrote:Strange, unlike in Explorer (Vista), in my AS it is Ctrl+Shift+F11
I think at least F11 should be added.MartinS wrote:I think F11 should be added
Adding Ctrl-Shift+F11 too would be a usability bonus.
I use WindowPad for all window-arrange-issues. Very easy to use (no-install), customizable (hotkeys), small and works with ALL windows.
Kind regards, KNUT
I find myself getting used to the new shortcuts for window arrangement in Windows 7.
Are you talking about keyboard shurtcuts (I do not know of) or about mouse gestures and dragging the window to borders?th. wrote:I find myself getting used to the new shortcuts for window arrangement in Windows 7.
They have introduced keyboard shortcuts like
						- Win+Up = Maximize,
 Win+Down = Restore/Minimize,
 Win+Shift+Left/Right = Move to another monitor.
I use Vista so it doesn't help...
BTW has anyone ever used the Alt+Space sequences?
Shift+ESC, all the timeth. wrote:BTW has anyone ever used the Alt+Space sequences?
Yes, I do Shift+Space, x as long as F11 does not work.th. wrote:BTW has anyone ever used the Alt+Space sequences?
You mean "Minimize the main window of Altap Salamander"? I never want Salamander (or any of its windows) minimized.Slanec wrote:Shift+ESC, all the time
