Ctrl+Alt+F11 in Find
mdruiter
Post by mdruiter »
Could Ctrl+Alt+F11 (FullScreen) perhaps also be made to work in Find?
Groente, Michel.
MartinS
Re: Ctrl+Alt+F11 in Find
Post by MartinS »
Strange, unlike in Explorer (Vista), in my AS it is Ctrl+Shift+F11
EDIT: But in Internal Viewer it is only F11, which is windows standard (works in Explorer too)
In Find it is unfortunately missing...I think F11 should be added
mdruiter
Post by mdruiter »
Maybe both Ctrl-Shift+F11 *and* F11!
mdruiter
Post by mdruiter »
MartinS wrote:Strange, unlike in Explorer (Vista), in my AS it is Ctrl+Shift+F11
I did not realize until now, that I typed Ctrl+Alt+F11 where I meant Ctrl+Shift+F11.
mdruiter
Post by mdruiter »
MartinS wrote:I think F11 should be added
I think at least F11 should be added.
Adding Ctrl-Shift+F11 too would be a usability bonus.
KNUT
Post by KNUT »
I use WindowPad for all window-arrange-issues. Very easy to use (no-install), customizable (hotkeys), small and works with ALL windows. :D
Kind regards, KNUT
th.
Post by th. »
I find myself getting used to the new shortcuts for window arrangement in Windows 7.
th. wrote:I find myself getting used to the new shortcuts for window arrangement in Windows 7.
Are you talking about keyboard shurtcuts (I do not know of) or about mouse gestures and dragging the window to borders?
th.
Post by th. »
They have introduced keyboard shortcuts like
  • Win+Up = Maximize,
    Win+Down = Restore/Minimize,
    Win+Shift+Left/Right = Move to another monitor.
See http://windows.microsoft.com/en-US/Wind ... -shortcuts for a reference.
mdruiter
Post by mdruiter »
I use Vista so it doesn't help...
th.
Post by th. »
BTW has anyone ever used the Alt+Space sequences? :?:
Slanec
Post by Slanec »
th. wrote:BTW has anyone ever used the Alt+Space sequences? :?:
Shift+ESC, all the time
mdruiter
Post by mdruiter »
Yes, I do Shift+Space, x as long as F11 does not work.
Slanec wrote:Shift+ESC, all the time
You mean "Minimize the main window of Altap Salamander"? I never want Salamander (or any of its windows) minimized.
