Batch Renaming and Filter
thomas
Post by thomas »
I was irritated by a strange entry (|*.dll) in the "Batch Renaming" mask. Today I found the solution, I've used "Filter" (STRG-F12) months ago.
I think it isn't helpful, if "Batch Renaming" use the mask of "Filter" as default option.
Re: Batch Renaming and Filter
Hi Thomas,
this only happens when the filter is active in the panel from which you launch the renamer plugin. This is exactly what I would expect to happen. Otherwise I might rename unexpected files, because I did not see them in the panel I came from, that is, the set of files I usually want to process.
thomas
Post by thomas »
Hello SvA,
I realy think that this is a fault. Because if I use a filter in a panel, I can make my file selection for "Batch Renaming" only with the active filter.
The mask in the "Batch Renaming" Plugin is for the name of the selected files. For this reason I expect the Mask: "*.*" as the default setting.
Example for the use of mask (|*.dll has no function in the mask, but it irritated extremely):
This part of help should make this thing clear:
Mask:
You can filter files for batch rename operation by this mask. It's especially important when you rename files in subdirectories (e.g. you want to rename only *.htm files).
So, mask is not important for selected (or focused) file(s) in panel, but for selected subdirectories or focused subdirectory. I think it's good that this mask is copied from panel filter because it will filter content of subdirectories to files visible in panel with that filter when you enter such subdirectory.
BTW, |*.dll means all names except *.dll.
thomas
Post by thomas »
Thank you for your declaration, but in my opinion the arguments are not persuasive.
I want to use "Batch Renaming" independent of the "Filter" settings in the Altap Salamander.
If I start with "Batch Renaming" incl. subdirectories I want to see all files anyway. If I require to filter the files, I can edit the mask now.
I think the most user use selected or focused file(s) in "Batch Renaming" and would prefer as default "*.*" like in "Search".
OK, I understand. We can change this easily, but I need to see more users who want it. So if you want *.*, please let us know in this topic. Thanks!
KNUT
Post by KNUT »
thomas wrote:I think the most user use selected or focused file(s) in "Batch Renaming" and would prefer as default "*.*" like in "Search".
I'm with you
Kind regards, KNUT
thomas
Post by thomas »
Petr Solin wrote:OK, I understand. We can change this easily, but I need to see more users who want it. So if you want *.*, please let us know in this topic. Thanks!
Please, I'm looking for supporters. :wink:
I've disabled the "Filters" because of this problem. I really prefer as default "*.*" like in "Search".
Am I alone in thinking this?
From my point of view, I can understand both sides - the prevetion of renaming files in subdirectories i a good reason for one and second is to use renamer and not be influenced by second option set by filters.
I think the best solution would be to have a check box on renamer main screen (there is actually nice place for it below the Exclude extension checkbox) when checked it would ignore the filtering option and have simple *.*.
I'm for keeping the current behaviour = copy mask. Pressing * after Ctrl+Shift+R doesn't seem too cumbersome if you want to reset the mask.
(I must have missed this thread, back when...)
Ditto.
I rarely use Filter (Ctrl+F12), though there have been times when I've scared myself, realizing after the fact that I've left a Filter enabled.
Never knew that Batch Rename would pick up as Mask, the active panel Filter.
Opening Batch Rename, I would expect either all or panel highlighted files to be displayed.
That said, I would rather error on the side of caution, keeping the current behavior, displaying the Filter/Mask files.
And with that I like the checkbox in the dialog idea.
That would allow the user the option to pick the method they want.
