UTF8 BOM detection not working in the CSV viewer
Radek Tetik
Post by Radek Tetik »
UTF8 BOM detection not working in the CSV viewer. See the attached file.
myq_report_uzivatele_01-02-2009_00-00-00_28-02-2009_23-59-59.csv
(227 Bytes) Downloaded 441 times
(227 Bytes) Downloaded 432 times
Re: UTF8 BOM detection not working in the CSV viewer
Radek Tetik wrote:UTF8 BOM detection not working in the CSV viewer. See the attached file.
UTF8-encoded CSV files are actually not supported until the next release of Salamander (2.52 beta2).
Great work Jan! Thank you! I'm happy that more and more plugins are starting to support Unicode ;)
