UTF8 BOM detection not working in the CSV viewer
Radek Tetik
UTF8 BOM detection not working in the CSV viewer. See the attached file.
- myq_report_uzivatele_01-02-2009_00-00-00_28-02-2009_23-59-59.csv
- (227 Bytes) Downloaded 441 times
- (227 Bytes) Downloaded 431 times
Re: UTF8 BOM detection not working in the CSV viewer
UTF8-encoded CSV files are actually not supported until the next release of Salamander (2.52 beta2).Radek Tetik wrote:UTF8 BOM detection not working in the CSV viewer. See the attached file.
