Consistent read error for sector of file in UDF ISO
DavidAns
Post by DavidAns »
Using the ISO file for Windows 7 Beta x64 (en_windows_7_beta_dvd_x64_x15-29074.iso, SHA1=E09FDBC1CB3A92CF6CC872040FDAF65553AB62A5, available from http://msdn.microsoft.com/en-us/subscri ... fault.aspx), try to copy file [UDF]\sources\install.wim to a directory on your disk. I see a consistent "Read error" for sector #00193B05 about 30% of the way through the copy. I've verified the hash for the ISO and also burned it to a CD and performed a successful installation, so this does not seem like a download error for the ISO file.
Any thoughts?
PS - So far Salamander 2.51 runs fine on Windows 7 Beta x86! :D
MartinS
Post by MartinS »
Confirmed on 7000.0.081212-1400_client_en-us_ultimate-gb1culxfre_en_dvd.iso
7-zip has no problem with the file.
Re: Consistent read error for sector of file in UDF ISO
DavidAns wrote:Using the ISO file for Windows 7 Beta x64 (en_windows_7_beta_dvd_x64_x15-29074.iso, SHA1=E09FDBC1CB3A92CF6CC872040FDAF65553AB62A5, available from http://msdn.microsoft.com/en-us/subscri ... fault.aspx), try to copy file [UDF]\sources\install.wim to a directory on your disk. I see a consistent "Read error" for sector #00193B05 about 30% of the way through the copy.
The problem has been fixed for the next release of Altap Salamander (2.52). (David, thanks for the verification!)
DavidAns wrote:PS - So far Salamander 2.51 runs fine on Windows 7 Beta x86! :D
Yes, we are testing Salamander also under Windows 7 Build 7000 now. It looks great.
