Missing 64bit keys in registry using Registry plugin
cincura.net
Post by cincura.net »
Hello *,
there's a visible key in regedit named "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\EMDMgmt" (it's location where ReadyBoost info is stored, BTW). But when using Registry plugin you can't see it (see att). Another example can be "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\ASR".
Probably 32bit vs. 64bit related. [similar 1]
Re: Missing 64bit keys in registry using Registry plugin
Thank you for the information. This problem will be fixed with 64-bit version of Salamander 2.53.
cincura.net
Interesting stuff is, that some keys the plugin can find, using search dialog. And then access it. It adds double slash to path. :roll:
I.e.
REG:\HKEY_CURRENT_USER\Software\\Classes\VirtualStore\MACHINE\SOFTWARE\Wow6432Node\Microsoft
Typing this path manually works too. :)
Jiri {x2} Cincura
