folder in user menu
frax
folder in user menu
Post by frax »
Hi is it possible to add a folder shortcut (for browsing in AS) as an entry in the user menu... ? If so, how... ?
You can use Hot Paths
Options > Configuration > Hot paths
(there press F1 for more help)
frax
Post by frax »
Unfortunately it is not an option, since I have filled up my ten slots of hot paths (and I use them frequently) - so I am looking for an option for the less frequently used folders that I use now and then.
Then, if you've had searched a bit then you would find this:
http://forum.altap.cz/viewtopic.php?t=1981
(salhotmenu.vbs)
frax
Post by frax »
ok cool, thanks! I searched for user menu, but not for hot paths.
even the "user menu" search string resulted in the listed link :-)
have fun
