More Hot Paths
Eric
More Hot Paths
Post by Eric »
I would be great, if I could define more than 10 hot paths.
Doesn't matter if I there are assigned Hot Keys, but the path should be shown in drop down 'Change Drive' Menu.
Thanks
Re: More Hot Paths
Eric wrote:I would be great, if I could define more than 10 hot paths.
Thanks
Have you checked http://www.altap.cz/salam_en/newver.html ???
- Structured and unlimited Hot Paths.
Eric
Post by Eric »
Of course, that the reason why I ask for this features :twisted:
But anyway, thanks for the hint.
rsignell
Post by rsignell »
Folks,
But unlimited hot paths is not available yet, only in the plan for "Next Altap Salamander versions", right?
Does anybody have a workaround? I have about 20 directories that I go to frequently and with Salamander 2.5 I'm limited to keeping only my top ten in the hot path.
Thanks,
Rich
You can allways use a customized user menu.
rsignell
Post by rsignell »
SelfMan,
I spent 15 minutes trying to figure out how to make a customized user menu that would allow to move to a specified directory, but couldn't figure it out. I tried searching the discussion for an example, but couldn't find one.
Could you please explain a bit more how to do this or post an example?
Thanks,
Rich
th.
Post by th. »
I am using this script (e.g. d:\tools\salhotmenu.vbs):
Set objArgs = WScript.Arguments
Set sh = WScript.CreateObject("WScript.Shell")
bFound = sh.AppActivate("Salamander 2.5")
if bfound then
	sh.SendKeys "+{F7}"
	sh.SendKeys objArgs(0) & "{ENTER}"
end if
and create user menu entries like this:
Command: d:\tools\salhotmenu.vbs
Arguments: "\\Server1\Share11"
Initial directory: $(SalDir)
Execute through shell: unchecked
Show item in User Menu Bar: checked
KNUT
Post by KNUT »
th. wrote:I am using this script (e.g. d:\tools\salhotmenu.vbs)
Very smart !!! My acknowledgments :D
Kind regards, KNUT
rsignell
Post by rsignell »
The script works perfectly -- great workaround to allow unlimited hot paths!
Thanks TH.!
As the answer is here :-), its not necessary to leave more comments :-)
Re: More Hot Paths
So how to have "unlimited" hot paths? please explain..
Does not work for me on Windows 10 Pro and Salamander 4.0 (run as Admin).
Re: More Hot Paths
The script does work, after a minor modification
32bit Salamander
bFound = sh.AppActivate("Altap Salamander 4.0 (x86)")
if bfound then
	sh.SendKeys "+{F7}"
end if
64bit Salamander
bFound = sh.AppActivate("Altap Salamander 4.0 (x64)")
if bfound then
	sh.SendKeys "+{F7}"
end if
the AppActivate must contain the proper application title.
Re: More Hot Paths
Vďaka.
