When I use the Plugin Batch Rename (Ctrl+Shift+R), the dialog box always comes up with the following check boxes checked:
Case sensitive
Only once in each name
I would like the above two boxes to be unchecked and the following boxes checked each time I open the renamer:
Regular Expression
Exclude Extension
Summary: I want the above two boxes checked and everything else unchecked.
Is there any .ini file or other file I can use to modify this plugin dialog box.
Please Help. TIA.
knightball
Default Batch Renamer(Renamer) Plugin Settings/Check Boxes
knightball
