Default Batch Renamer(Renamer) Plugin Settings/Check Boxes
knightball
Post by knightball »
When I use the Plugin Batch Rename (Ctrl+Shift+R), the dialog box always comes up with the following check boxes checked:
Case sensitive
Only once in each name
I would like the above two boxes to be unchecked and the following boxes checked each time I open the renamer:
Regular Expression
Exclude Extension
Summary: I want the above two boxes checked and everything else unchecked.
Is there any .ini file or other file I can use to modify this plugin dialog box.
Please Help. TIA.
knightball
Enough would be that the checkboxes retain the "last used" state.
knightball
Is that possible?
th.
Post by th. »
You can recall the last settings with Ctrl+L (Options -> Last Used).
knightball
Great!!!! Thanks alot!
