Just for information: Icon in ControlPanel/Software
McLion
Post by McLion »
This is not a real issue, just an information:
Before 2.5 there was the Salamander Icon in the Add/Remove Software Control panel. With final release this has be gone. It's a standard installer icon now.
Re: Just for information: Icon in ControlPanel/Software
Not sure what you're meaning about "icons"?
Anyhow, for me both SS & AS show the regular Salamander icon in A/R.
Note that 2.5 release is now listed as Altap Salamander rather then Servant Salamander.
McLion
Post by McLion »
see attachment[/img]
The only thing is the missing registry entry:
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Altap Salamander 2.5]
"DisplayIcon"="C:\\Program Files\\Altap Salamander 2.5\\salamand.exe,0"
I've created a registry file. (Assuming you've installed salamander to the default folder)
altap_salamander_missing_uninstall_icon_fix.zip
Missing icon in Add/Remove programs list for Altap Salamander fix. (default install location)
(358 Bytes) Downloaded 590 times
McLion
Post by McLion »
Perfect. Added the missing Registry entry with success. :D
Thanks.
SelfMan wrote:I've created a registry file. (Assuming you've installed salamander to the default folder)
I will fix the setup script, thank you!
Strange.
Wonder why is displays the "correct" icon for some, but not others? Even without the registry entry?
Perhaps on initial install, it would be correct, but if you cleared your Shell Icon Cache, it would revert to a "default" icon?
