Printing manual for Salamander 2.5RC2
jerrydf
Post by jerrydf »
I would like to print out the manual for Salamander 2.5 RC2. Where can I find and download it?
With Salamander 2.5 RC2 comes help (look at menu Help). Choose the Contents command, select chapter you want to print and then choose the Options > Print command.
Guest
Post by Guest »
I can do that but it is not as useful as a complete printable PDF file as most other programs now provide. Thank you for your reply.
Yes, the PDF format is better for printing.
Moving your idea to Feature Requests.
