Hello,
I'm trying to use Servant Salamander 2.5 RC1 to restore\undelete
files from my PDA but I'm not sure how does it work.
Since the free trial download doesn't have a help. Would you mind
guiding me what am I missing ?
1) Install Servant Salamander 2.5 RC1 - Full version
2) Make sure plugin Windows Mobile is loaded
3) Connect PDA to ActiveSync
4) Then I try to browse the Salamander UI to verify if the Windows
Mobile folders can be viewed, but PDA folders are not listed.
Hope you can help,
Windows Mobile 5 Plugin
dcardozo
undelete for Windows Mobile
so, the undelete doesn't work for Windows Mobile.
1) do you plan to include it in a future version?
2) do you have another product that can do this?
if not
3) do you know of any product that can do this?
if not
