Windows Mobile 5 Plugin
Suzuki
Post by Suzuki »
Hello,
I'm trying to use Servant Salamander 2.5 RC1 to restore\undelete
files from my PDA but I'm not sure how does it work.
Since the free trial download doesn't have a help. Would you mind
guiding me what am I missing ?
1) Install Servant Salamander 2.5 RC1 - Full version
2) Make sure plugin Windows Mobile is loaded
3) Connect PDA to ActiveSync
4) Then I try to browse the Salamander UI to verify if the Windows
Mobile folders can be viewed, but PDA folders are not listed.
Hope you can help,
The Undelete plugin works only with FAT 12, 16, 32 and NTFS partitions.
On file system plugins (Windows Registry, FTP, WinSCP, Windows Mobile), archiver plugins (ZIP, RAR, 7-Zip, TAR, etc) and network drives undelete operation is not supported.
Suzuki
Post by Suzuki »
I see, so basically Salamander can't recover data from Windows Mobile 5.
Thanks,
dcardozo
undelete for Windows Mobile
Post by dcardozo »
so, the undelete doesn't work for Windows Mobile.
1) do you plan to include it in a future version?
2) do you have another product that can do this?
if not
3) do you know of any product that can do this?
I'm sorry, but no, no, and no.
