Several minutes agou I tried to install SS on Windows Vista build 5536. everything so far have been running well except for two things:
- when a new item appears in a folder dipslayed in a panel, the item is not displayed regardles the item origing - regardles the fact the item has been created inside/outside the SS, regardles the item has been moved F6 between panels etc. - the panels are siply not refreshing once they have been displayed when the folder has been changed.
This seems to me like the panels are not receiving FS change notifications from ntfs.
- when you create a file with SHITF-F4 with a .TXT extension, the SS tries to start notepad to edit the new item. But the text editor states "cannot find the file, do you want to create the new file".
The startup command for the notepad (as appears in task manager) is: "notepad.exe test.txt" so the correct one.
O.
Vista 5536: panels seem not to receive fs chang notifs
ondra@sevecek.com
ondra@sevecek.com
Re: Vista 5536: panels seem not to receive fs chang notifs
ok. solved. when I start SS "as administrator", everything works fine.
So, this is only a feature-request for SS to offer the eleviation on Vista.
O.
O.
