Downlad
Re: Downlad
A kde je tam na stažení nějaká instalace?
Re: Downlad
Vím zatím jen o dvou Open Salamander verzích, které mají release:
PepaR
Re: Downlad
Tu sa tiež niečo chystá začiatkom roka 2026:
viewtopic.php?p=74022#p74022
Re: Downlad
Aktualizácia:
Open Salamander 5.0.3 Preview
https://github.com/0xeb/salamander/releases/tag/v5.0.3
SHA-256:
815c28dbc79d6177438d2e8be2ff41012a1783d9665bc851f2286d84098ef747 OpenSalamander-v5.0.3-x64.zip
Pár obrázkov:
https://imgur.com/a/open-salamander-5-0 ... ew-OEjt4ic
SHA-256:
Pár obrázkov:
Re: Downlad
Open Salamander 5.0.4 Preview
https://github.com/0xeb/salamander/releases/tag/v5.0.4
Thanks for counter settings store in Rename plug-in!
Re: Downlad
I'll note that 5.0.4 & the Tabbed version use the same (Windows) Registry (main) key, HKEY_CURRENT_USER\Software\Open Salamander, which... makes it a bit difficult to... run them both.
Well, not actually to run them, but to be able to get a good feel for how they may compare against one another, much less if settings from one might conflict with settings in the other?
(As it is, I used Tabbed first. And when I threw 5.0.4 in [in Sandboxie], expecting to see Plugins, to have them available - which they are not in Tabbed, I did not see them in 5.0.4 either. And I thought, weird, as I thought I remembered reading that they were there? And checking today, yep, 5.0.4 web page says they are, but I wasn't seeing them? So then I ran 5.0.4 outside the Sandboxie, & still they were not turning up. With that, renamed existing HCU\Software\Open Salamander, then fired up 5.0.4, & with that, Plugins were there [in 5.0.4]. Not quite sure just what is going on, but I'll plug away...)
Re: Downlad
I do see a different REG keys for regular AS 4.0 and AS 5.0 Preview -
- 2026-01-13 01.png (35.1 KiB) Viewed 386914 times
Re: Downlad
Yes, 4.0 & 5.0 use different registry key (trees).
But different versions of 5.0 (like above 5.0.4 & the above Tabbed version) both use the same HKCU\Software\Open Salamander\ tree.
Re: Downlad
Díky za odkazy na preview a vysvětlení registrů, hodí se mít přehled mezi verzemi
- KRtek™
Re: Downlad
Tabbed version (Samandarin) is now using different registry hive (currently it's HKCU\Software\Open Salamander Samandarin).therube wrote: 13 Jan 2026, 18:09 I'll note that 5.0.4 & the Tabbed version use the same (Windows) Registry (main) key, HKEY_CURRENT_USER\Software\Open Salamander, which... makes it a bit difficult to... run them both.
KRtekTM, KRtek™
Open Salamander: Samandarin
https://samandarin.net/
Re: Downlad
Nová verzia 5.0 zo dňa 27. 1. 2026.
https://github.com/0xeb/salamander/releases/tag/latest
Porovnanie plug-ins, len pre info (vľavo: v5.0 dev vs. vpravo v4.0):
https://i.imgur.com/f7lncIc.png
UI najnovšej verzie:
https://i.imgur.com/AHjuL57.gif
Re: Downlad
Nová verzia:
Open Salamander 5.0.5
Feb 15, 2026 - https://github.com/0xeb/salamander/releases/tag/v5.0.5
