Downlad
Jenc
Downlad
Post by Jenc »
Kde je prosím reálně ke stažení Open Salamander?
Resp. zdrojový kód, dá se zkompilovat?
Všude čtu jen reklamní sdělení, ale ani na GitHubu či jinde není jediný release.
Vyvíjí se tento program, nebo ne?
Gtein
Re: Downlad
Post by Gtein »
A kde je tam na stažení nějaká instalace?
PepaR
Re: Downlad
Post by PepaR »
Vím zatím jen o dvou Open Salamander verzích, které mají release:
PepaR
Re: Downlad
Tu sa tiež niečo chystá začiatkom roka 2026:
viewtopic.php?p=74022#p74022
Re: Downlad
Aktualizácia:
Open Salamander 5.0.3 Preview
https://github.com/0xeb/salamander/releases/tag/v5.0.3
SHA-256:
815c28dbc79d6177438d2e8be2ff41012a1783d9665bc851f2286d84098ef747 OpenSalamander-v5.0.3-x64.zip
Pár obrázkov:
https://imgur.com/a/open-salamander-5-0 ... ew-OEjt4ic
Re: Downlad
Open Salamander 5.0.4 Preview
https://github.com/0xeb/salamander/releases/tag/v5.0.4
Thanks for counter settings store in Rename plug-in! :)
Re: Downlad
I'll note that 5.0.4 & the Tabbed version use the same (Windows) Registry (main) key, HKEY_CURRENT_USER\Software\Open Salamander, which... makes it a bit difficult to... run them both.
Well, not actually to run them, but to be able to get a good feel for how they may compare against one another, much less if settings from one might conflict with settings in the other?
(As it is, I used Tabbed first. And when I threw 5.0.4 in [in Sandboxie], expecting to see Plugins, to have them available - which they are not in Tabbed, I did not see them in 5.0.4 either. And I thought, weird, as I thought I remembered reading that they were there? And checking today, yep, 5.0.4 web page says they are, but I wasn't seeing them? So then I ran 5.0.4 outside the Sandboxie, & still they were not turning up. With that, renamed existing HCU\Software\Open Salamander, then fired up 5.0.4, & with that, Plugins were there [in 5.0.4]. Not quite sure just what is going on, but I'll plug away...)
Re: Downlad
I do see a different REG keys for regular AS 4.0 and AS 5.0 Preview -
2026-01-13 01.png (35.1 KiB) Viewed 386835 times
Re: Downlad
Yes, 4.0 & 5.0 use different registry key (trees).
But different versions of 5.0 (like above 5.0.4 & the above Tabbed version) both use the same HKCU\Software\Open Salamander\ tree.
Re: Downlad
Cylven
Re: Downlad
Post by Cylven »
Díky za odkazy na preview a vysvětlení registrů, hodí se mít přehled mezi verzemi :idea: :wink:
KRtek™
Re: Downlad
Post by KRtek™ »
therube wrote: 13 Jan 2026, 18:09 I'll note that 5.0.4 & the Tabbed version use the same (Windows) Registry (main) key, HKEY_CURRENT_USER\Software\Open Salamander, which... makes it a bit difficult to... run them both.
Tabbed version (Samandarin) is now using different registry hive (currently it's HKCU\Software\Open Salamander Samandarin).
KRtekTM, KRtek™
Open Salamander: Samandarin
https://samandarin.net/
Re: Downlad
Nová verzia 5.0 zo dňa 27. 1. 2026.
https://github.com/0xeb/salamander/releases/tag/latest
Porovnanie plug-ins, len pre info (vľavo: v5.0 dev vs. vpravo v4.0):
https://i.imgur.com/f7lncIc.png
UI najnovšej verzie:
https://i.imgur.com/AHjuL57.gif
Re: Downlad
Nová verzia:
Open Salamander 5.0.5
Feb 15, 2026 - https://github.com/0xeb/salamander/releases/tag/v5.0.5
