Can´t copy to shared folder
Re: Can´t copy to shared folder
check my DM
jaymz1097
Post by jaymz1097 »
@SelfMan found my phone number and called yesterday, thanks a lot!
So to sum this up, the problem was with accessing the shared folder from Salamander when opening it over network, even though the folder was created on that very computer. So simply using the path to the folder on C.\ did the trick and copying works fine.
Thanks for all the help and keep it up!
You are welcome. 👍
