As my CPU is very heavily used while unzipping, I would like to ask the developers to consider a Pause/Resume button while unzipping. Similar to the one now we have while copying.
Vili
Pause while unzipping files
- Josip Tosic
While we're on the subject...
That "Do you want to cancel this operation?" dialog doesn't understand [Esc] key as "No." That wouldn't be too bad if it didn't pass the keypress to the parent dialog. So, if I try to chase it away with [Esc] it does nothing, but then when I click "No" button, I'm once again prompted to cancel the parent operation.
- Josip Tosic
