Pause while unzipping files
Guest
Post by Guest »
As my CPU is very heavily used while unzipping, I would like to ask the developers to consider a Pause/Resume button while unzipping. Similar to the one now we have while copying.
Vili
Click the Cancel button in progress dialog box and then Cancel in the confirmation message box.
Guest
Post by Guest »
I am totally ashamed now... I should have noted it. Never Cancelled :)
Thank you!!!
Vili
Josip Tosic
Post by Josip Tosic »
While we're on the subject...
That "Do you want to cancel this operation?" dialog doesn't understand [Esc] key as "No." That wouldn't be too bad if it didn't pass the keypress to the parent dialog. So, if I try to chase it away with [Esc] it does nothing, but then when I click "No" button, I'm once again prompted to cancel the parent operation.
Which archive type (ZIP, RAR, 7ZIP, ...) do you pack (or unpack)?
Josip Tosic
Ach, crivens! I forgot 'bout this post. I've tried this "feature" again in RC3 and I cannot reproduce it. If you have an open bug please close it.
