strange single drivebar bug in rc2
LioMajor
Post by LioMajor »
i've got a real strange bug in using single drive bar
all driveletters are collapsed , even the first C: is unreadable or clickable
using two drivebars works properly
Try clear this option: Options > Show > Lock the Toolbars.
Then you should be able to set toolbar size.
LioMajor
Post by LioMajor »
thx, worked. ;)
