When i copy in the right panel (for example), and try to past in left panel i can´t see "Paste" in Context Menu. It´s a bug?...
I use the last version/xp home.
Greate tool!
Thanks for any help,
Joe
Copy/paste Context Menu problem
Q. Please try to open Windows Explorer window for the same directory (Shift+F3 from Servant Salamander panel) and let me know if the Paste command is there.
A. Yes
Q.Are you using Servant Salamander 2.5 RC1? There was problem with context menu in Servant Salamander 2.0.
A. I´m using Servant Salamander 2.5 RC1 (trial).
I go to install the version 2.0 to see if the result is equal.
Regards
A. Yes
Regards
1. The context menu for current directory could be also opened using Alt+Shift+F10 shortcut. I assume the Paste command is not presented in this menu too?
2. Note that Servant Salamander doesn't show the Paste command when the clipboard doesn't contain file reference. Please try to copy some file from Servant Salamander to clipboard (Ctrl+C), then switch to Windows Explorer and paste it there. Does it work?
