unrar plugin bug - Unix hidden attributes
- crystalidea
some archives can't be displayed while WinRar successfully deals with this .rar format. Possibly you need yo upgrade to a newer unrar version.
sample:
http://rapidshare.de/files/25622804/fot ... o.rar.html
sample:
The provided file could be extracted without problem (SS 2.5 RC1) on my computer.
fotografii_kapel_ochen_krasivo.rar
857 157 bytes
MD5: 756DCC54C9BCDEE8411EA7A5A5ABE668
Could you please post detailed information about your problem?
OS version, SS version, error message, etc.
857 157 bytes
Same hereJan Rysavy wrote:The provided file could be extracted without problem (SS 2.5 RC1) on my computer.[...]
Kind regards, KNUT
- crystalidea
SS 2.5. RC1. Archive file listing is empty, after extraction - no files appeared.
Unrar v.2.17RC1
Unrar v.2.17RC1
OS version?XPiS wrote:SS 2.5. RC1. Archive file listing is empty, after extraction - no files appeared.
Unrar v.2.17RC1
Could you please check the MD5 checksum?
- crystalidea
Windows XP SP2, MD5 is correct. I can even record a video to prove you that this error is real.
I believe you, please don't waste your time. We have several other reports from our users regarding this issue.XPiS wrote:Windows XP SP2, MD5 is correct. I can even record a video to prove you that this error is real.
Could you perform this test on another computer?
- crystalidea
sure, At least at home and at work the error is the same.Jan Rysavy wrote: Could you perform this test on another computer?
Couldn't believe it would depend on, but one never knows: Are you using localized windows? And if so, which one?XPiS wrote:sure, At least at home and at work the error is the same.
P.S.: XP SP2 PRO CZ (localized & locales set to CZ) extraction works.
The files in your archive have SYSTEM/HIDDEN flag, pressing Ctrl-h should help.
Martin
Martin
I can't quite understand why the rar plugin interpretes these files as having a system attribute. Does it interprete the Unix attributes wrongly?
Unrar 3.0 (command line version by Eugene Roshal) does not. Neither does 7-Zip.
- crystalidea
MartinS wrote:The files in your archive have SYSTEM/HIDDEN flag, pressing Ctrl-h should help.
Martin
The problem is solved!
LOL
Thank you Martin!MartinS wrote:The files in your archive have SYSTEM/HIDDEN flag, pressing Ctrl-h should help.
Martin
LOL
Yes, it looks like a bug, we will fix this problem.SvA wrote:I can't quite understand why the rar plugin interpretes these files as having a system attribute. Does it interprete the Unix attributes wrongly?
This bug is fixed now. Attributes from Unix and BeOS archives are ignored (inspired by unrar.exe) now. Thanks for your report!
