unrar plugin bug - Unix hidden attributes
crystalidea
Post by crystalidea »
some archives can't be displayed while WinRar successfully deals with this .rar format. Possibly you need yo upgrade to a newer unrar version.
sample:
http://rapidshare.de/files/25622804/fot ... o.rar.html
The provided file could be extracted without problem (SS 2.5 RC1) on my computer.
fotografii_kapel_ochen_krasivo.rar
857 157 bytes
MD5: 756DCC54C9BCDEE8411EA7A5A5ABE668
Could you please post detailed information about your problem?
OS version, SS version, error message, etc.
KNUT
Post by KNUT »
Jan Rysavy wrote:The provided file could be extracted without problem (SS 2.5 RC1) on my computer.[...]
Same here :D
Kind regards, KNUT
crystalidea
SS 2.5. RC1. Archive file listing is empty, after extraction - no files appeared.
Unrar v.2.17RC1
XPiS wrote:SS 2.5. RC1. Archive file listing is empty, after extraction - no files appeared.
Unrar v.2.17RC1
OS version?
Could you please check the MD5 checksum?
crystalidea
Windows XP SP2, MD5 is correct. I can even record a video to prove you that this error is real.
XPiS wrote:Windows XP SP2, MD5 is correct. I can even record a video to prove you that this error is real.
I believe you, please don't waste your time. We have several other reports from our users regarding this issue.
Could you perform this test on another computer?
crystalidea
Jan Rysavy wrote: Could you perform this test on another computer?
sure, At least at home and at work the error is the same.
Datalog
Post by Datalog »
XPiS wrote:sure, At least at home and at work the error is the same.
Couldn't believe it would depend on, but one never knows: Are you using localized windows? And if so, which one?
P.S.: XP SP2 PRO CZ (localized & locales set to CZ) extraction works.
MartinS
Post by MartinS »
The files in your archive have SYSTEM/HIDDEN flag, pressing Ctrl-h should help.
Martin
I can't quite understand why the rar plugin interpretes these files as having a system attribute. Does it interprete the Unix attributes wrongly?
Unrar 3.0 (command line version by Eugene Roshal) does not. Neither does 7-Zip.
crystalidea
MartinS wrote:The files in your archive have SYSTEM/HIDDEN flag, pressing Ctrl-h should help.
Martin
:shock:
The problem is solved!
LOL
Martin
Thank you Martin!
XPiS wrote::shock:
LOL
There is a "filter" symbol displayed if some files are hidden...
SvA wrote:I can't quite understand why the rar plugin interpretes these files as having a system attribute. Does it interprete the Unix attributes wrongly?
Yes, it looks like a bug, we will fix this problem.
This bug is fixed now. Attributes from Unix and BeOS archives are ignored (inspired by unrar.exe) now. Thanks for your report!
