I've found a strange behavior...
When I copy/move files to another location, if I modify the "*.*" to something like "A*.*" I loose the first character of the filename in the process, instead of Salamander appending a character to the original name.
Copy/move: Strange *.* behavior
- Josip Tosic
I don't understand what you mean, read this part of help (version 2.0):Mem wrote:But what about the incosistence when using asterisk at the beginning vs. at the end?
Operation masks can contain special characters - asterisk (*) for the rest of the name or the extension and question mark (?) for a single character. So the operation mask 'new_*.???' will generate names which begin with 'new_' followed with the rest of the original name (from the fifth character to the end), and end with (.) followed with three characters from the original extension.
Operation masks are usually used for simpler operations like changing extensions in the group of files (you can use '*.html' for renaming .htm files to .html files, etc.).
Windows "copy" command, Total Commander, Norton Commander, FAR, etc. In fact, I don't know any file manager which handles it the way Josip and you suggest here.Mem wrote:And where else can this standard be found?
