is there any way to permanently delete the files shown under Undelete, i.e. make them NOT recoverable?
schroeder
Delete Undelete files?
I knoooooow!Jan Rysavy wrote:It is not possible to shred particular (already) deleted file. Btw, interesting idea for the Undelete plugin
Jan Rysavy wrote: There is command Plugins > Encrypt & Decrypt > Clean Disk Free Space which will shred all free space on given partition. Unfortunately it takes same time...
Ah! Thats probably what I need. Thanks!
And BTW, what a great piece of software you guys put together. Two thumbs up!
One more question though about the memory consumption of SS. If I minimize the program to the task bar the memory footprint goes down to 900K (awesome! ) but then after about 20 seconds it goes up to about 2.5 MB. Why is that?
Thanks,
schroeder
Please post this question (copy&paste) as separate thread, for easier navigation. Specify your OS version. It looks interestingAnonymous wrote:One more question though about the memory consumption of SS. If I minimize the program to the task bar the memory footprint goes down to 900K (awesome! ) but then after about 20 seconds it goes up to about 2.5 MB. Why is that?
Works like a charm. Thanks.Jan Rysavy wrote:It is not possible to shred particular (already) deleted file. Btw, interesting idea for the Undelete plugin
One more thing: when I call the Undelete view after cleaning the free space a folder called ZZZZZZ.ZZZ with about 5000 0-byte files with funky (random) filenames remains. What's that one for?
schroeder
